Those look fine, proportionally scaled. The only thing is that because of rotation a lot of uv-space is wasted. You can do an optional fix manually with uvToolkit > Arrange and Layout > Orient Shells. After you orient them, consider doing Modify > Layout, as it will try to accommodate most of uv-space, If it rotates those shells, then see its options, set the RotationStep to 90.ooo
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
