Hi All,
I'm having an issue with sweep mesh.
I've created a custom profile for the shape, one out of poly and one out of curve to see if that is the issue.
I need to be able to flip the shape as it is using the wrong side as the front. I've have tried every setting but can't find it. I've tried to freeze transforms as well and rotated the curve before applying it to sweep but it hasn't made any changes.
Many Thanks
Mark
Solved by mark.playford. Go to Solution.
