Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
One of the stacked UV shells rotate as I apply layout
3 REPLIES 3
sysoeva.ma
589 Views, 3 Replies
why UV shells are overlapping like this when I apply auto layout? I need the similar ones to be stacked, but somehow they rotate. How can I fix this?
3 REPLIES 3
Kahylan
in reply to: sysoeva.ma
Hi!
If you don't want the shells to rotate, just take away the tick mark next to "Rotate Shells" in your UV layout settings. That should fix the problem.
If the rotation is already there from the beginning and you need the shells on top of each other, take a smaller value for the "rotation steps" setting, because at 90 maya can't rotate it to match the other identical pieces.
I hope it helps!
sysoeva.ma
in reply to: Kahylan
Yeah, thak you for the help, but when i took a smaller rotation value somehow there appeared just more overlaped shells..
sysoeva.ma
So i decided to start over again and now everything is ok
probably i accidentally broke something
but thanks anyway
