I can't select an object, only faces in Maya 2016. I've toggled F8 and selected Object mode via right mouse button to no avail. I haven't used Maya in a couple of months. Have I forgotten something obvious?
Solved by mspeer. Go to Solution.
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
