Normal/Faces Issue
Normal/Faces Issue
Normal/Faces Issue
I am currently facing some issues after I extrude certain objects/meshes on a current project.
I tried to check it it was a vert issue but when I try to reverse specific verts I still get the same issue with my normals.
Seen below:
I have never come across this issue before and don't seem to know how to fix it, please help.
Best Regards,
Dani
damaggio
you dont reverse vertices only faces , reverse them and unlock the normals then set a new angle.
mihirsbcc
Select the geometry, from the Mesh display first click on CONFIRM then SET TO FACE that will fix the problem. Then you will use SOFTEN EDGE command to soften the edges.
thank you so much guys! it worked!
