Multi-Cut Tool not working in Maya 2022
Hi! I had install new clean version of Maya 2022 but Multi-Cut Tool not work at all. I pressed Ctrl-key, in object mode (and all others too) and I can`t see any edge loop lines, tool not snapping to verticeses and works if make manual cut beyond object place only (attached). I use Maya approximately 5 years and last my version was 2018 and all worked perfectly. Restart not helped. The tool works fine sometimes but randomely and I dont know by what reason. Language of keyboard is ENG, I not installed any scripts and plugins. I need to work, please help!
The tool works like this only.
Replies (34)
brentmc
Hi Sean,
You should have started a separate topic for this one.
It appears the Pivot Orientation Handle preferences is affecting the mirror tool. This is clearly a bug so I've logged an issue to track this.
MAYA-121383 - Poly Mirror: rotation handle affected by pivot manipulator preference
Thanks.
Brent McPherson
Principle Engineer
malcolm_341
Sherwin, is that you? I'm in 2022.2 and the rotate handle is there, make sure history is turned on and also try pressing t right after you perform the mirror cut, I don't see the little history edit box that should appear after doing a mirror cut in your screenshot.
mcginnc
I just tested on Win using 2022.3 and when I do a mirror cut, the manipulator is there with rotation.
Catherine McGinnis
Maya Quality Assurance
mcginnc
As for the cut not showing up/happening - do you have symmetry on?
Catherine McGinnis
malcolm_341
@brentmc @syracoj
Original posters bug still occurring in 2022.3 video attached.
brentmc
Thanks Malcolm.
I can reproduce this when I have a 3D View + UV Editor + DirectX 11 rendering as shown in your setup.
I have opened an issue to track this:
MAYA-121603 - Multi-Cut tool not working after starting Maya in DirectX 11 mode
Brent McPherson
Principle Engineer
malcolm_341
@brentmc
Oh that's great, you figured out the repro steps. Nice.
mcginnc
Hey - I don't see a response here. I just tried this in 2022.3 and see the usual manipulator. Are you not seeing the entire thing - as you mentioned the rot handles seemed to be missing.2022.3_mirror_cut.jpg
Catherine McGinnis
mcginnc
Hey NM - I got it. This has been logged as MAYA-121383.
Catherine McGinnis
seanpatrick.sherwin
Observer
Observer
seanpatrick.sherwin
Observer
Observer
hi catherine. thanks for looking into it. i also found the cause. for some reason the manipulator orientation was turned off. i assume this happened during an upgrade. i'm not sure why anyone would want it turned off. see the screen shot above
enea.arki4KUK9
reset mirror tool Mesh-->Mirror. In mirror option window Edit-->reset setting. Fix my problem
enea.arki4KUK9
ok i repeat some time to make sure this is not just random fix illusion. but you can try also change the viewport (nothing fancy just press 2X the spacebar for me switch to 4 panel viewport and again 2X to bring back perspective) something like to refresh the viewport i dont know i m not a engineer.
Observer
Observer
the solution has worked for me, thank u!
MDA3Q7KSX
Community Visitor
Community Visitor
go to panel -> tear off... then close the poped up viewport, back in maya hold space and go to perspective, thats it
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
