Mesh exported from ZBrush is double-sided
I am trying to retopologize my sculpt made in Zbrush but when I export it as a .obj file into maya the sculpt ends up being double sided which makes retopology impossible.
Also for some reason GoZ for Maya is not installed,
I was wondering if anyone had an advice for this issue?
hamsterHamster
Do you want to say, that being double-sided the object is irretopolgizable? You can go to the object's shape node in Attribute Editor, section Render Stats and deselect Double Sided anytime.
If you notice that your object is with flipped normals, then go for Modelling>Mesh Display>Reverse. Sometimes, when importing objects from other software, you might wish to Unlock Normals (same menu) before reversing.
As to GoZ, it is not a default Maya plugin, you need to install it yourself.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
 This did not work 😞
I attached a video of what I mean by double sided (the mesh is empty inside?)
hamsterHamster
All the meshes are empty inside, like baloons. However, did I see the double-walled polygons in your video? Sorry, the captured framerate was too low. Maybe you have exported some model that has "skin" thickness, like an eggshell. Check the Zbrush export options again.
In Maya you can select the object, go to Face selection mode (F11) and double-click one of the faces - entire object is likely to be selected. Now. if you hit Delete, what did change?
,,,_°(O__O)°_,,,
Hey! I tried and here is what happens. I also updated GoZ but it doesn't change much. My mesh is also a merge of different meshes so maybe that is where the issue comes from
hamsterHamster
So, the problem seems solved. Also, you can apply Mesh>Fill Hole to make mesh watertight.
,,,_°(O__O)°_,,,
thanks 🙂
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
