Hi there,
I was worked on project and from version 23 to 25 my scene is almost empty i lost everything, i was saving and increment. There only a wheel all green. an camera plane. Of course the objects are not in the outliner, i tried to Replace all "nan" or "nan(ind)" with "0". But that changed nothing. i dont know what to do to recovert de geo from those scene the auto save are completely empty.
Solved by hamsterHamster. Go to Solution.
I could not find that green wheel.
You still have things in the Outliner, just go Edit>DeleteAllByType>History, then select all remaining scene contents and press Shift+P (Unparent).. select the grayed-out geometry and press Shift+H (ShowSelection), or in the ChannelBox change Visibility to ON.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
I searched for the cases like yours and indeed, it was matter of changing the -nan(ind) with 0. The v25 before editing displayed only that green wheel, while after editing this:
Still had 3 more warning messages, but those seem to be uv-related, which is not that important.
,,,_°(O__O)°_,,,
