My maya project becomes a mess when I'm restarting the program, everything was perfectly lined up and fixed, yet this happens? See picture.
Is there a solution for this!?
Solved by brentmc. Go to Solution.
Solved by damaggio. Go to Solution.
That is strange. Did you use any booleans in your modeling process?
It looks like all the verts tried to merge together or something.
Maybe if you upload you scene I can help a bit more.
Could you have switched versions of Maya between creation and re-opening the file?
If so try opening the file in Maya 2016 (or whatever version was used to create it) and doing Edit > Delete All by Type > History to create a new file without history that you can load into Maya 2017.
It is regrettable but history does not always translate correctly between major versions of Maya. If this is the case and you are able to post your model I can open an issue to track this.
Thank you.
Brent
Hi Danouie, it seems that you did not read carefully or understood Mr. Brent suggestion to you about cleaning your history, that's the reason your file got messed up, try to avoid saving any maya scene with tons of history, I'm not gonna explain what this all means, it will be better if you do your own search on google or the Maya docs about history and how and when to delete it.....it's a must read and a lot of beginners don't understand this.
The car was looking sweet but take a pause and study construction history.
Good luck and come back if you get stuck again.
It is true that deleting history during modeling and before saving will go a long way towards avoiding these issues.
However, that is not an excuse and we take these types of bugs very seriously. The problem is that the final scene file does not always tell us how the model got into that state and we usually need consistent steps to reproduce the problem from scratch.
Brent
I had the same issue in the newest version and it seems like Autodesk is a lazy a** and haven't fixed the problem yet. I think we need to reconsider which software we should use because there are free softwares that has an amazing community, works really well and doesn't has a massive size for no reason and its bugs gets fixed instantly instead of just saying we take it seriously and do niothing about the problem.
