Announcements
Maya Change Precision
Admiral.Pixel
Admiral.Pixel
Hi all. Is there a way to change the precision when extruding/beveling/etc. into 3 decimal places? Thanks in advance. (Please see image.)Untitled.png
brentmc
There doesn't appear to be a way to set the display precision for the in-view editors so I would suggest using the channel box instead since you can customize the channel box display precision.
I will enter an improvement request for the in-view editor to use the same precision setting as the channel box.
Thanks.
Brent
Brent McPherson
Principle Engineer
Admiral.Pixel
Hi there and thanks for replying. Is it OK to also request for some improvements? Here are some of my suggestions:
Inset Faces = The "Offset" option from the "Extrude" doesn't give equal inset/offset (please see image)
Relax Modifier = A relax modifier like in Softimage XSI that relaxes the mesh without losing its volume. The relax tool in "Sculpt Geometry Tool" shrinks the mesh. The modifier GUI is a slider much like in XSI that updates in real-time. Thanks in advance.
mspeer
Hi!
If you don't get the same result as in Max you probably don't use the latest Version of Maya, with Maya 2017 update 4 it works here.
Admiral.Pixel
Hi there sir and thanks for reply. I updated my Maya recently but still the offset faces doesn't "offset/inset" properly like the one in Max
