maya batch export blendshapes as obj
davidtorresmonteiro
davidtorresmonteiro
is it possible to batch export each of the blendshapes of a character as a separate obj file?
Do you eventually know a script wich offers this funtionality?
Thanks a lot!
David
alec.andersenLP8AU
Hello @davidtorresmonteiro,
This is not something that is supported in Maya natively. This process could be performed manually but you would require a script to do so in an automated way. If you are looking to begin scripting there are many phenomenal tools for getting started.
I hope this has answered your question!
davidtorresmonteiro
Thanks!
I found a script that batch imports and exports obj files.
The only thing i am missing is that it does not maintain the names of the blendshapes when exporting...
will2power71
Could you tell me the name of the script you use? I'm also interested in being able to do this.
hasmikWYGZG
Community Visitor
Community Visitor
it would be much appreciated if you could share the script with us
Thanks)
The-Digital-Shaman
Try OBJ Toolkit 1.2 by Jan Jinda perhaps?
"This toolkit is a set of simple scripts tailored to provide clean, easier and more effective workflow for handling OBJ files in Maya.
Thanks to the Import as blend shape options it keeps all your scene hierarchy, geometry UVs, shader assignments etc.
It was intensively tested on projects like Pacific Rim: Uprising, Venom and lately Avengers: Endgame."
