Is it ok to have a vertex connect to more than 4 edges?
Wanted to know if having a vertex connect to 5 edges would cause any problems with my model
mspeer
Hi!
That's not a problem, it's a very common technique.
It's not totally bad but it should be avoided for proper edge flow because it can cause deformation problem. But in the face area you can see them on the cheek, at the top of the nostril , at the top of the outer brow, because these areas quite stiff rather than the other areas of face. On the other side there are effectively helpful if you place them in a correct positionGenerally these are called stars or poles. You can see more information www.topologyguides.com here
