I probably switched sth at random. I've tried exporting this mesh from fbx to obj but no luck. I'm pretty sure that I did sth dumb.
https://www.youtube.com/watch?v=Bq38oLfMPWs
Windows 10
Solved by brentmc. Go to Solution.
Turn off Edge Transform Constraint in the Modeling Toolkit panel on the right of the screen.
Edge slide is activated by dragging the manipulator with Shift+Ctrl held down but there is a bug in 2018 where it can become enabled by accident. This issue is fixed in 2018 Update 1 so you should update your version of Maya.
Thanks.
Brent
