Hi!
I am having trouble doing my UV. I use camera base to cut my model, then unfold, and hit layout. It doesn't turned out to be the way I want. The Uv are overlapping each other. Is there anyway I can fix this?
Thanks a lot!
You have to manually cut new sews so the unfold can unfold it more, without the overlapping. More complicated models doesn work that fast to just click camera based and unfold.
Thanks! Adding seams works. I also used the optimized tool to relax it out and it fixed most of the issues.
