Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
I can't extrude using curve and face
7 REPLIES 7
Message 1 of 8
1642 Views, 7 Replies
I have done this many times before, on other computers and it works perfectly, I know the basics. Here I attach a photo of how it looks, it is as if I made a normal extrude to a polygon but with the faces already stretched. I have Maya 2020, on a MacBook. Thanks for your time.
7 REPLIES 7
Message 2 of 8
stuzzz
It should work if you first select the polygon then the curve before extusion.
Is there a error message ?
Message 3 of 8
in reply to: stuzzz
I don't get any error messages 😞 now the polygon appears in black
Message 4 of 8
mspeer
Hi!
Don't change the "local" selection mode after you selected the face, just select the curve.
Message 5 of 8
stuzzz
@mspeer is right.
Select the curve in the outliner directly.
Message 6 of 8
in reply to: mspeer
For a moment I almost started to believe that you could not select the curve directly, because in reality I could not select it, I had to put the curve in smooth, a solution that I saw in another post, but the main problem continues...
Message 7 of 8
mspeer
Hi!
Thanks for the video, now I can see the problem.
Please check your settings for the Extrude,
Extrude Face Options -> Curve Settings (set to "Selected")
Message 8 of 8
in reply to: mspeer
Thank you so much!
