how to wrap a mesh around a surface?
nick.holliday
nick.holliday
As part of a helmet im modelling, Id like to wrap a collection of panels around the back portion of the helmet (screenshot attached).
A friend suggested i flatten the helmet portion out, add a blend shape between the two, and then wrap deformer the panels to it. This hasnt quite worked as i have to perfectly flatten the surface out which is near impossible.
Would anybody know of any other techniques?
thanks
sean.heasley
Hi @nick.holliday
You could use a shrink wrap deformer.
This video has a quick tutorial on it that should help you out!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
nick.holliday
aha! thanks for that - will take a look
sean.heasley
Hi @nick.holliday
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
nick.holliday
been tussling with this one for a while. Ive just reverted to using a bend and cage deformers. But your tip certainly looks easier 🙂
sean.heasley
Hi @nick.holliday
Great! Is there anything else you need help with or do you have any other questions?
nick.holliday
that's all thanks 🙂
