How to UV map a curve surface easily?
sistemaseprodutos
sistemaseprodutos
Hi folks, I need help!
I want to apply a texture to a road, this texture has detail lines so I need to find a way to map it correctly so the texture will follow the geometry curves, the geometry is plane and very simple, but going manually isnt helping because certain paths are too angled
Thanks in advance,
damaggio
Use Unitize and then Legacy unfold .Roads are quite easy to UV map.
sistemaseprodutos
thanks I did some basic roads and it mapped well and quick now
what is legacy unfold for?
damaggio
Legacy has different options than Unfold 3D.
Christoph_Schaedl
ZooTools does have a great script to unfold such stuff.
https://create3dcharacters.com/maya-tool-unfold-tube/
https://linktr.ee/cg_oglu
