How to delete a boolean operation?
04:29 PM
I create a cube. Then I create another cube and I use Mesh > Booleans > Difference on the first cube. Then I perform some operations and eventually change my mind - I don't want the boolean anymore. I can go to the Channel Box, select something in Inputs and use Edit > Delete node to remove the operation - but it doesn't work with booleans for some reason. When I delete a boolean node, nothing happens. How do I remove a boolean?
