Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Hotkey for Assign material?
5 REPLIES 5
JacksonLamme
1064 Views, 5 Replies
I have hundreds of materials in my scene and rightclicking then going to arnold and shimmying down to AIsurface takes too long.  Is there a faster way?
Many thanks
5 REPLIES 5
Kahylan
in reply to: JacksonLamme
Hi!
I'm not quite sure, are we talking about new materials or existing materials?
if it is just a question of creating new materials, you can use a script like this one to do so:
import maya.cmds as mc
sel = mc.ls(sl = True)
for s in sel:
    mat = mc.createNode("aiStandardSurface", n = "{0}_material".format(s))
    sg = mc.createNode("shadingEngine", n="{0}_SG".format(s))
    mc.connectAttr("{0}.outColor".format(mat), "{0}.surfaceShader".format(sg))
    shape = mc.listRelatives(s, s= True)[0]
    attr = mc.listConnections("{0}.instObjGroups[0]".format(shape), p = True)[0]
    mc.disconnectAttr("{0}.instObjGroups[0]".format(shape),attr)
    mc.connectAttr("{0}.instObjGroups[0]".format(shape),"{0}.dagSetMembers[0]".format(sg))
If you need to connect the right existing materials with their geometric counterparts, it is going to be harder, because you would need very strict consistent naming conventions to write a script that does that.
I hope this helps!
JacksonLamme
in reply to: Kahylan
Thank you! I'm not sure what that does, does in make control or s the hotkey?  What about just a new AIstandard surface?
damaggio
I agree with Kahylan,  your question is hard to understand Jackson. Maybe you can gives a better description.
JacksonLamme
in reply to: damaggio
I only usually create ai standard surface,  but I have to click 3 times and find it in a long list every time,  when I would prefer to just default to having an ai standard surface on my materials.   I've searched for this for quite a while and not so cut and dry
Kahylan
If that is what you want then I understood you correctly, you can just create a hotkey that runs the script that I posted above using the hotkey editor. This should give you the result you want.
Here's a tutorial on creating and assigning custom hotkeys
https://www.youtube.com/watch?v=3Xhnnao6AXY
