Hi I have created a group. They will only move as one if I select the group in the Outliner. If I select the whole spine in the viewport, it only selects one mesh. Please assist. Thank you
Use the up arrow key on your keyboard to select the group.
This is normal behavior. Selecting in viewport will normally select the lowest object in a hierarchy. If you want to select by the highest you can turn on "Select By Hierarchy And Combinations"
More info can be found here:
