Gemetry text with Extrusion enabled and without extrusion enabled
morethanamotion
morethanamotion
Hi I could really use the held of Maya Experts here. I have a Text with extrusion enabled, and when I check the Deformable type, I get this result:
But when I disable or Uncheck the Enable Extrusion, I get this result:
is three a way that I can achieve the same edges or result for the text's Fore face even the Enable Extrusion is checked?
THANK YOU SO MUCH IN ADVANCE.
damaggio
Disable Deformable type and set Extrude divisions to 1.
