dotted edge loop in viewport
The issue is shown in the screenshot I provided. The edge becomes dotted when inserting an edge loop but straight when extruding the edge. Why?
Erik
sean.heasley
Hi @Anonymous and welcome to the community!
You probably accidentally hit the toggle soft/hard edges display. To fix this, select your object and then the shortcut for this is shift+RMB -> Soften/Harden edge -> Toggle soft edge display.
If that doesn't work, you can go to Settings/Preferences -> Display -> Polygons to Soft/Hard, Save Preferences and close Maya.
Then when you restart Maya you should be all set!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi Sean,
Im currently on a trip and have not access to maya. I will return in a
couple of days and look into it again.
Thank you for your respond.
Kind Regards
Erik
sean.heasley
Hi @Anonymous
No problem!
I'll keep an eye on this thread and check in with you in a few days unless you get back to me before then!
sean.heasley
Hey @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi Sean,
Yes, it worked. Thank you for your help. I have Accepted the solution.
Erik
