Default uv set
Default uv set
horizor
Message 1 of 1
Default uv set
horizor
I have a model with 100 shells, with uv mapping in uv set named map1. In next working process i found that some my shells have one more set ,named uv set1 and this set becomes default.
This set i cant delete  i must selecte every shell with it and change in map1 in manual mode. Im so tired from this bug or whatever it is. Maybe you tell me ,you can combine all shell and change set for them in couple cliks, but its important for me to keep original name of my shells.
This problem have a lot of people i know it. Autodesk can you... or even you must improve uv set management.
If you dont how ,i will tell you some my ideas...
Replies (0)
