Announcements
Disable out clicking from component mode?
Message 1 of 8
So I have just started learning Maya, and I found this feature very frustrating, and cannot find a way to disable it.
The problem: When in component mode if I click to another object, it is selecting it. Is there a way to disable it?
(The live selection and layering methods are not my favourites to solve this.)
Replies (7)
Message 2 of 8
mspeer
Hi!
- Make it unselectable (Template)
- Hide it (Visibility "off")
- Viewport Isolate Selected
Message 3 of 8
Hi!
Ty for the reply,
I"m using the isolation, but there are scenarios when I need other meshes to be visible.
Making it unselectable, works, but too much steps if there are a bunch of meshes, then I need to re-enable them.
Thats why I"m looking for a general change to make it unable to misclick. Maybe a plugin or script if it cannot be changed.
Message 4 of 8
mspeer
Hi!
Make use of Display Layers to change the Display Type (like "Template" and "Reference") for a group of objects with one click.
Message 5 of 8
Hi!
Yes, it works, but too much steps.
I would love if the tool itself would work like that when I enter to component mode.
Message 6 of 8
mspeer
Hi!
You can add this to the Ideas for Maya.
https://forums.autodesk.com/t5/maya-ideas/idb-p/968
A Mel script should be possible, but there are a lot of problems to overcome when changing Drawing Overrides for all other objects in the scene and then change this back later, so i doubt you will see any workable script that does what you want for a wide range of different scenes.
What i suggest instead:
Use a local selection mode, for example right-mouse-click on an object -> Face, if you then accidentally select an other object (in Object mode) you can remove this selection instantly with a second click on this object.
Message 7 of 8
Hi!
Yes, as I learn the new tools, I see there are some that relies on this feature, so a toggle function would be the best, so you could toggle it to enable-disable the "out clicking" function depending on what you currently do.
I will try to summarize it and post it to the ideas, thanks for sharing it!
For the time being, I will just get used to it.
Message 8 of 8
inet3537
Observer
Observer
Hi! Try this script, maybe it will help you. It creates a layer and puts all objects in it except the selected one. https://github.com/SPluzh/MayaObjectComponentSelectionMode
