Creating icosahedron
I'm trying to model a sphere that takes on a special T=7 icosahedron geometry (for the purposes of modelling a virus that exhibits this specific type of geometry). It should look exactly like the model on the right in the attached image, where the subdivision/tessellation mode is triangular with essentially a pattern or pentagons and hexagons.
I'm in Maya 2018 and I've tried using the primitive soccer ball but it doesn't give me the right pattern or number of pentagons/hexagons. I've also tried using the platonic icosahedron primitive and increased the subdivisions to 4 which brought me close but had some extra triangles in between the "flowers" of pentagons and hexagons as seen below. It's like I just want to delete these extra triangles and turn the "flowers" of pentagons and hexagons so that they all tile and fit correctly.
I appreciate any and all help! THANKS!
Unfortunately what you're trying to create isn't a Platonic Solid, since it's not a regular pattern.
You may have to tile a bunch of those patterns together and deform it into a sphere by using a combination of bend or wave deformers to create hemispheres etc.
mspeer
Hi!
There is no easy way to do this in Maya. You can do this with modeling (using mathematical correct values for angles/vertex positions) and/or scripting.
Hi, thanks!
I had a feeling that's what I would end up having to do...
Figured out a solution that wouldn't require scripting or complicated modelling thanks to a friend/colleague:
Visit http://levskaya.github.io/polyhedronisme/ which uses Conway Polyhedral Notation to generate various irregular polyhedrons.
Type in A10wD into the recipe bar, download the OBJ, then import the file to Maya and that's it!
mspeer
Hi!
It's done outside Maya now, but a really nice tool, i wish we had something like this inside Maya.
Thanks for the link.
