can´t select 2 at the same time (polygon & Curve) and rotate tool failure maybe
markusdamon5
markusdamon5
Hello everyone,
i´m new here and I have some very important question.What you hopefully have a solution for!
Why I cant select polygon(cylinder) and Curve at the same time , even though I use shift + LMB, I use that for extrude. (watch picture 2 select).
My second question is why isn´t my rotate tool like others (default), i saw in tuorials they aren´t like my. With the others rotate tool is always a ball where you can then turn as you like ! (watch picture rotate fail i choose the rotate tool in this picture ,but ball doesn´t appear)
And finally, someone can tell me some tipps, how I can best use cleanup ,whenever I use it I change my object completely.
I hope you can help me further would be a very big help !
mspeer
Hi!
1. Use Object selection (Select By Object Type not Select By Component Type)
2. Check Pivot Position (maybe use Center Pivot)
markusdamon5
thanks msspeer you have solved a problem ,but the rotate tool isn´t fixed.
can anyone one help me, please ?
Maybe the X Y Z axes are to far away ,because I usually see arrows in the respective axes in tutorials.
PLEASE I NEED HELP!
mspeer
Hi!
You tried 2. ?
For further help please upload a scene-file.
markusdamon5
Thanks for your quick reply !!
Yes, the 2. tip that you have left me I graduated. (modify>center pivot)
I don´t think the problem lies with the scene, because it is a given scene (tutorial).
mspeer
Hi!
Check the size of your Manipulator
- Windows -> Settings/Preferences -> Preferences -> Display -> Manipulators
- Windows -> Settings/Preferences -> Preferences -> Edit -> Restore Default Settings
- Hotkeys ("+" and "-") to resize handles.
markusdamon5
Thank you so much ,you are the BEST MSPEER !!! I had the problem for a while already. I had already given up and finally it was solved.
