Hi, I have a problem with nurbs
sometimes I need to use nurbs to make complex shapes that I cannot with polys, to reconvert after
BUT
I don't know how to connect two points of two different curves (for instance when you duplicate and flip to have the perfect simmetry)
how can I do?
I tried grouping but after I must make two loft instead of one
I also tryed using the shape method, selecting the shape from outliner and making a null group, freezing all and parenting with
parent -r -s,
also here remain two different curves
can you help me??
thanks a lot
Solved by dave.rose. Go to Solution.
yes you are, but unfortunatly it gives me some glitch
it makes edges that I don't want and split the whole shape in a strange way
I'm sure that the cv points are in the right place, because I used the snap to grid and for sure they touch
NO I didn't
I'm very bad with nurbs, I would learn better to model procedurally (as use path in photoshop instead of raster)
but I'm more comfortable with polys
I've only flipped the scale
I really don't know how to read it
YES!!!
thank you very much
you solved a question that is not written anywhere, I search for this solution for a long time
thank you so much 🙂
