Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Can't weld vertices in Instances with Target Weld
11 REPLIES 11
Message 1 of 12
SpaceCoyote
1196 Views, 11 Replies
I'm not sure if this is related to my recent update to Maya 2023.2, but I just noticed that I am unable to use the Target Weld tool to weld vertices together for any meshes that are instances but I can still weld instance edges without any issue. For meshes that are not instanced, welding verts and edges works without issue and exactly as expected. Is anyone else having this problem and know of a solution? Target Weld is pretty essential for my modelling workflow and I'm currently working on something with a lot of instances.
11 REPLIES 11
Message 2 of 12
SpaceCoyote
in reply to: SpaceCoyote
Not sure when or if this bug will get addressed, but a great workaround I discovered is malcolm341's weld scripts. They seem to work perfectly with instances and may be even better than Target Weld.
https://youtu.be/kAOyQoMOGA4
Message 3 of 12
Getting the same issue. =[
Message 4 of 12
zyu3
Hi, I got the same issue. did you get the solution for this? I spent whole night to on this.
Message 5 of 12
zyu3
Hi, did you get a solution for this issue?
Message 6 of 12
zyu3
in reply to: zyu3
Hi, I have the same issue, and looking for a solution. would be pleasure if you can tell me anything
Message 7 of 12
xinyicindyw
Same issue here, any available solutions perhaps?
Message 8 of 12
damaggio
in reply to: xinyicindyw
Use control V or finish modeling then instance it.
Message 9 of 12
lizwalcher
This issue still persists a year later. Any word on a fix?
Message 10 of 12
damaggio
in reply to: lizwalcher
still works fine here.
Message 11 of 12
mcginnc
Try using it while in Wireframe mode.
Catherine McGinnis
Maya Quality Assurance
Message 12 of 12
lizwalcher
in reply to: mcginnc
Yes-- it works in wireframe mode, and it works with XRay toggled on. But it should also work in shaded view so you can actually see what you're welding, and has in fact worked that way in previous versions of Maya. I just cracked open old reliable Maya 2018 to confirm. It works just fine in those older versions-- this is a bug with Maya 2023 / 2024. Are there any plans to fix it?
Technology Administrators
