Automatic Unwrapping of multiple objects in different groups doesn't work
I have hundreds of objects which I select and then click "UV>Automatic".
It doesn't do anything except give me the error message:
// Error: line 0: Doesn't work with multiple objects selected.
The objects I select are inside different groups in different positions in hierarchy. The automatic function does work fine when I only perform it on a single object and when I perform it on the same selection of my hundred of objects but when I first moved them all to the same hierarchy level outside of all groups or inside one single group. That seems absurd to me. So my question is:
How can I create automatic UVs for all these hundreds of objects in different groups all in one go? I don't want to select each one by hand and click Automatic and then do the same on the next and keep doing this hundreds of times.
Am I doing something wrong or is that another one of Mayas brilliant features that has not been addressed in 20 years?
stuzzz
The error message is quite self explanatory. It works with a single selectin
Here's a workaround.
duplicate all the concerned geos.
combine them
make an automatic UV
Then Mesh->transfer the UV with the options bellow
delete the combined mesh after deleting the history
mspeer
Hi!
What Maya version are you using?
I tested UV -> Automatic with many objects in different groups in Maya 2020.1 and it works without any problems.
