Hello autodesk member. I have problem with texture
Fristly I export character animation (Alembic). From 3d maya to work in 3ds max. also is working perfectly in animation. But Without any material/texture.
So I have mayafile.mb include with texture and I have ABC.file Without tex
I try in 3d maya assign texture from mayafile.mb to ABCfile.abc so can't change the texture. Only the color changed maybe I create something wrong.
Will how can fix that. And thank you. ๐
โ
ABC file not write any texture or uv. so only I have the mayafile.ma with texture. and I try applying on abc not work. only change the color. and I try in max same problem.
Hi!
You need UVs on your model without texture coordinates a proper mapping is not possible.
You can try Mesh -> Transfer Attributes.
