zero area faces error
ZEICHEN.TRICK
ZEICHEN.TRICK
Hi folks,
does any one know how to fix zero area faces?
regards Rick
pshwayka
Try using the Mesh->Cleanup command. Under the "Remove Geometry" section of the options screen you can select "Faces with zero geometry area."
ZEICHEN.TRICK
i know that option.
the command delete the zero area faces and when i reface the spots the issue starts ahead.
but in the meantime i find out  when i scale up the whole modell the problem dissapear.
ZEICHEN.TRICK
no the problem still exists
