Announcements
Wrong text when I export
Erro 1.PNGErro 2.PNGI'm creating a text in Maya, exporting in FBX, and uploading in Sketchfab, but the same is going with wrong faces..
The Template Link in Sketchfab: https://sketchfab.com/models/0dd9719b3189487b80de7ea960156a06
sean.heasley
Hi @Anonymous and welcome to the community!
Do you have any geo there in Maya that might have reversed faces?
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
ppriyamadhu2000
Community Visitor
Community Visitor
Same problem here. Plss help
hamsterHamster
Simply triangulate front and end caps of the letters, the risky places will become obvious.
If necessary, either edit the erroneous areas or undo triangulation, cut the caps in strategic places and re-tesselate again. Repeat, until its good to go.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
