- Mute
- Permalink
- Report
Hi
Has something changed with an update or something...? I swear when I've used UV sets in Maya before, I could get it working no problem. I could have sworn that you selected your recquired UV island, loaded up the UV Set Editor, clicked on New, and then hit Update and it was sent to the new set...? Or you click on copy and it goes to a new set...? Whenever I do it now, nothing seems to happen. I'll click on the new UV set, but it doesn't appear to isolate/show what should be there. In other words, it doesn't hide everything else I didn't select/move and only show what I did. Everything is in the same place in each set.
It tends to do it if I go to UV Sets > Copy UVs to UV Set > Copy into New UV Set, but with the current pieces I'm working with at the moment, it isn't. 😕
