Uv red areas
Uv red areas
Uv red areas
I have modelled this wii balance board (low poly). Now i try to unwrap its uv’s but I have a problem.
I used planar projection separately for upper faces, bottom faces, sides and power button. However red areas appear as in the screenshot.
Then I try automatic uv projection, the ratio goes mad as in the screenshot. Some of the the uv shells become squares instead of rectangular also sides’ shells height changes. If i try to change scale then red areas appear again.
I cleared history, checked for overlapping faces yet cannot solve the problem.
Have any ideas?
Thanks a lot!
hi, thank you. I've looked at the link, and tried it, flipped faces. Also I changed the uv unfold. The red areas are gone. However the faces i flipped get cut from the shell body.
(I flipped the faces without cut from the shell from the flip menu but did not work).
just cut that red part and after saw it
thank you, I did it. but still have red areas. Tried another unwrapping and this is the result:
cant get rid off this distortion problem. the only way when all shells are white is auto mapping but this time all rectangles become square:
I feel like I'm in a loop :S
you try texture that model?  if have no problem, dont pay attention on it.
