UV mapping problem
UV mapping problem
mmurray4835
UV mapping problem
mmurray4835
Hi, I've got a UV problem that's driving me nuts. There are three UV shells that I can"t select or delete. I've tried deleting the UVs and redoing, doing automatic, doing by hand, I even tried rebuilding the section where this is happening and they're still there. In the screen shot the unselected one is the problem.
u21mcdl2030
if you can share the file then i can look  into it
mmurray4835
Well, I ended up just rebuilding the object. It was just a simple cabinet. If it ever happens again I'll post the file. Thanks.
