Announcements
UV map error
UV map error
ZEICHEN.TRICK
UV map error
ZEICHEN.TRICK
hey folks,
i got a little problem.
somthing is wrong with my UV´s or my mesh.
when i hit 3 on the keyboard for smooth mesh preview my UV map changes into somthing that isnt good.
normal mode
smooth mesh preview
thanks for helping
best Rick
Perhaps using smooth mesh preview isnt the ideal way to go about things. If you would like to smooth your edges for a more organic mesh you can use the Smooth Edges tool in the Mesh Display drop down menu.
_sebastian_f
@Anonymous smooth mesh preview aka subdivision modeling and soft or hard normals are very different things.
@ZEICHEN.TRICK try deleting your history after uv mapping. helps in most cases.
Same error here: NORMAL VIEW (1)
SMOOTH (3)
