Transfer UV's
Transfer UV's
Transfer UV's
Hi.
I have a high weight and low weight model. They both currently share a set of UV's, but I don't want these UV's. I want a much straighter set for Substance Painter. So I have made the UV's I want as a second set on the high weight model, but I can't work out how to transfer this second set to the low weight model. Here I made some pics.
You prob didn't need a pic, but ... so there is a pic. I am staring at the transfer attributes window but I don't see the answer there. They share a UV set so... presumably there is a way (I hope there is a way) to copy set 2 from high to low based on set 1? At least that was what I was thinking to do.
ty.
oh Smiley Happy
I worked out a way. I made a copy of the high weight with both UV sets and then transfered attributes - vertex position and all UV sets - based on current UV. Bit of a head scratcher to work out which order to select them in ... but it worked.
I am betting there is a simpler solution.
Solved by your try
very nice Heart
