When press Extrude Button, i can't modify extrude options (i have the same problem with Bridge, Bevel and Add Divisions).
You may have accidentally disabled your history. (That will cause what you are seeing.) At the top of your screen, there is a small icon that looks like a clock. (You may need to click on the vertical bars to expose it.) Make sure it is enabled, then try your extrude again.
Muchas gracias!... Thank a lot!...
