Toolkit problems: Manipulator tool don't appear
soledad.ramirez
soledad.ramirez
When press Extrude Button, i can't modify extrude options (i have the same problem with Bridge, Bevel and Add Divisions).
pshwayka
You may have accidentally disabled your history. (That will cause what you are seeing.) At the top of your screen, there is a small icon that looks like a clock. (You may need to click on the vertical bars to expose it.) Make sure it is enabled, then try your extrude again.
soledad.ramirez
Muchas gracias!... Thank a lot!... Cat Embarassed
