Switch from an edge selection to vertex
t_smith5
t_smith5
Is there any way of being able to switch from a selection of edges to vertices like you can in 3ds Max? In Max, you can hold down Ctrl whilst either in Edge, Vertex, Polygon, or Border mode and then select another one to switch. For instance, you can switch your edge loop selection so it selects the vertices instead. Is there anything like that in Maya? Thanks.
mspeer
Hi!
a) Main menu: Select -> Convert Selection -> ...
or
b) CTRL +  right click -> ...
t_smith5
Perfect. Thank you. 😄
