Step Snap Drop Down Slow to Activate
Jrtrudeau
Jrtrudeau
Hi All,
Lately (or intermittently, I'm not sure) when I go to select relative from the step snap drop-down it won't activate until I click inside the viewport. The reason this is an issue is that in order for me to input a value for step snap I have to: choose relative from the step snap drop-down, click inside the viewport, then got back to step snap and input the value. The lag is the same when I turn off step snap but this causes less of a problem. I attached an example to explain it a little more clearly. Because I don't know where to begin for a solution, I attached my computer specs below as well. Thanks for any help or insights that you have.
Specs:
OS - Windows 10 Build 18362
Memory - 64gb
CPU - AMD Threadripper 3960X
GPU - GTX Titan x2  Driver 436.30
Justin Trudeau
Set Design | Parametric Modeling | Digital Fabrication
JustinRTrudeau.com
amaterasu-qbb
The best way is to create a tool in the script and use the marking menu to launch the tool, but I don't know.
Sorry.
mspeer
Hi!
That's because you added the Tool Settings to Hypershade.
The Tool Settings are sensitive to the current used window and can change based on the focused window.
So in this case the settings change when you change the focus from Hypershade to Viewport.
This has no effect on the usability of this tool, but I recommend to keep the Tool Settings it in it's own floating window or dock it anywhere else.
