Solid Shatter error : "globals.mel line 27. An error occurred while running t.."
Branlorio
Message 1 of 13
Branlorio
Hi, I have this error message ""globals.mel line 27. An error occurred while running the Solid Shatter""
when i'm applying Solid shatter, i deleted history and applied it on a closed surface.
 https://youtu.be/i5I28eN4QmU
How could i solve this problem, please?
Replies (12)
Message 2 of 13
mspeer
Hi!
Please upload a scene-file.
Message 3 of 13
Branlorio
The file is here
Message 4 of 13
mspeer
Hi!
Assign a material to the whole mesh (not individual faces).
Select the object... assign material, then it works.
Message 5 of 13
Nicolaas.tanghe
I have the same error and applying a texture on the whole file does not fix the issue.
 Here is my file.
I also tried using a diffrent model this did not fix the issue.
Message 6 of 13
Nicolaas.tanghe
even just trying it on a cube it doent work
Message 7 of 13
mspeer
Hi!
You also need to delete history.
Message 8 of 13
Nicolaas.tanghe
I also deleted my history.
Now also it seems my 3d gismo is unable to change size restarting also does not fix.
It seems stupid making a new post about that but it is impossible 4 me to do anything now.
Message 9 of 13
Nicolaas.tanghe
OK so deleting the non deformer history does work a bit however.
MY maya file just crashes now when i try i on my geometry.
Message 10 of 13
Nicolaas.tanghe
seems like the safe recovery was possible but then after shattering i cant shatter again.
Message 11 of 13
Nicolaas.tanghe
If i manuelly cut of parts of head and then try to shatter those  it scales the pieces to a verry large size.
Message 12 of 13
mihirsbcc
Solid Shatter is a funky tool. Search for some free scripts (mel or python)., will save your life.
Message 13 of 13
ardakekulluoglu
The same error is still ongoing in 2025.
