'Snap Rotate' Tip....
After years of rotating objects then going into the channel box to enter 90 degrees manually, I watched a tutorial last week where they set the Rotate Tool to "Snap Rotate" Never knew there was an option for this, and just though I'd share. I now leave it set to snap by default.
I have´nt 2008 till now, but in 8.5 you can hold down the J-Key during the rotation - this snap-rotetes also the object with discret steps. Or you enter the "multi-transform-tool" with Ctrl+T and then press Shift during the rotation for 5-Degree-Snaps.
Good Luck!
