Smoothing problems
Smoothing problems
FalconCrest
Advisor Advisor
Smoothing problems
FalconCrest
I have a problem with a particular mesh.  When I smooth the mesh, I get this infinity polygon, which goes on forever into the viewport, sometimes maya will crash after smoothing ?
tony.su
Autodesk Support
Autodesk Support
Which versions of maya you use?
first of all upgrade your progame to the latest sp.
http://knowledge.autodesk.com/support/maya/downloads#?sort=score
If it don't work, could you zip your scense file and uplpad it?
Tony Su
Product Support
FalconCrest
I'm using 2015 SP4. Can I send the crash scene info ?
tony.su
Autodesk Support
Autodesk Support
I need your scene file to reproduce this issue. So Could you zip it and upload?
Tony Su
Product Support
FalconCrest
I found a solution, although I'm not going to declare this problem as solved. If it should arise in the future, I will surface this thread again. The solution is to export the object as OBJ then re-import as OBJ. Smoothing then works successfully, without hiccups.
