Separate objects onto a single UV Set
Is it possible to put separate objects onto the same UV Map/Set?
thank you
Its_jay
Yes
If you combine multiple object to one object
Than you can have all uv’s in one
Thank you
If I group the objects then I get the UVs on a single mesh.
Should I 'combine' or 'group' and is there a difference from a UV map perspective?
thank you
Its_jay
If you group them you can’t move or edit all uvs same time till you combine all in one object
If I remember it correctly you dont even need to group nor combine them. Simply select both objects and open the UV Editor.
Had to work like that for the last 2 month, created some environment asset sets for a game.
(not able to check in program atm, correct me if i am wrong :3)
@Anonymous
@Its_jay
Thank you for the help (kudo given).
I wanted to have a single map to transfer to Substance Painter.
Grouping works and so does combine and I think that combine is the better option.
Yes if I select multiple options then they both show up on the UV Map
thanks again
