Selection tool working incorrectly
carolineoglesby2
Message 1 of 9
carolineoglesby2
The selection tool isn't working. When selecting a geometry component (verts, faces, edges) and I click once on it, it selects a random other face usually on the bottom of the object. Maya otherwise works. Is my graphics card just bad?
Example: I am putting my mouse where the red X is in the picture. But it is selecting something on the bottom of the object. You can see my tool settings. It is not set to nearest component.
I have tried:
Resetting selection tool, resetting Maya preferences, creating a new scene, trying with a new object, updating my drivers. The Graphics driver says it is up to date.
Computer specs:
Version is Maya 2020
Computer: HP Pavilion Laptop 15-cs3xxx OS: Microsoft Windows 11 Home (64-bit)
Processor: Intel® Core™ i5-1035G1 CPU @ 1.00GHz
Graphics: Intel® UHD Graphics 26.20.100.7926
Replies (8)
Message 2 of 9
semhjas
is that only with this paticular object, or with everthing? is there any history on the object?
Message 3 of 9
carolineoglesby2
Its multiple objects, usually larger ones with more faces.
The object I'm showing I made with berzier curves revolved into a NURBS then converted to polygons. I tried remaking it from the original curve, and deleting history. It previously had some error about UVs not existing but doesn't anymore.
I tested with new objects, like a default polygon sphere. It had trouble picking the right faces still. With a small cube, it did it correctly briefly.
Message 4 of 9
carolineoglesby2
Message 5 of 9
semhjas
could you upload the whole scene? have you also checked if some kind of selection symmetry is on?
Message 6 of 9
brentmc
Does seem to be graphics card related from your description.
Try changing Preferences > Display > Viewport 2.0 > Rendering Engine to DirectX 11 and then restart Maya.
Certified driver versions can be found here - not many Intel ones on the list and the UHD one has a slightly different driver version so that is something else you could try.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/simplecontent/content/maya-certified-...
Brent McPherson
Principle Engineer
Message 7 of 9
carolineoglesby2
Here you go
Message 8 of 9
carolineoglesby2
Thank you, that seems to have worked!!
Message 9 of 9
shilov.kirill
Thank you so much!
