Selecting the parent of hierarchy without highlighting the children?
Message 1 of 10
Hello valiant Maya users,
I'm sorry to post about such a basic subject, but it's been driving me mad and I can't seem to find a solution, even after spending the day reading help files and forums.
So here's my problem : is there a way for me to select the parent in hierarchy without highlighting all its children, or at least highlighting them with a different color?
As an animator I have to select multiple objects hundreds of times per day, and transitioning from Softimage and Max, I'm having quite a hard time with the display of selections in Maya. I get it that it can be useful to see the relations between objects when selecting, but because they all get highlighted with the "lead object" color, it's just ridiculously confusing, as it looks exactly the same if I select just the parent or the whole hierarchy!
Thanks for your help!
Replies (9)
Message 2 of 10
I wouldn't mind knowing a definitive answer to this also. I have looked extensively though the settings and preferences and found nothing of the kind.
Message 3 of 10
lee.dunham
as far as im aware its not possible with any nodes maya ships with. the highlighting comes with the parenting im afraid. a workaround i might use is a group on an object you would want parented then parent constrain it to the parent, then in pref turning sub-selection highlighting off.
if anyone has a better (and more informed) way of doing this, i would also too, love to hear it 🙂
Message 4 of 10
halfstone
I guess this is just something I've gotten used to in my workflow - I ALWAYS leave my selection set to objects, so I always use the up-arrow to navigate to the top of a hierarchy, keeping an eye on the channel box to see the names of what I'm selecting.
In your "Display" window under "Transform Display" there is a setting called "selection handles". If you select a node in your hierarchy and choose that option, you'll see a little "+" at the pivot of the object. In component mode, you can select this little "+" and move it to wherever you like.
Anytime you select this icon, that particular node in your hierarchy will be selected, regardless of what level it is on, or what selection mode your software is set to.
It's not the answer you are looking for, but it's a workaround. As I said, this lack of color-coding has been part of my workflow all along so I guess I don't notice it.
Message 5 of 10
You can turn the highlighting of in settings --> selection --> selection child highlighting
documentation
Message 6 of 10
Vstanish
That would be great to know!
In case if I don't want to use constrain (but parent directly) + I dont want to change it globally, nut just for ctl and obj under. When I select a group - I do want its children to be highlighted, but for ctls - I don't.
I found in the Shape node of ctl =>Object Display => Selection => Selection Child Highlighting - but that doesn't do anything for me 😞
Message 7 of 10
hamsterHamster
Prefs > Settings > Selection >...
The one you found in the shape is for the third option UseObjHighlightSetting .. change to NeverHighlight and try selecting hierarchies.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Message 8 of 10
Vstanish
If i switch it to Never highlight - it works, but it does it for everything in the scene, I do not want it so.
I want to do it only fort certain objects in the rig that parented directly under. It seems to me intuitively that Selection under Object Display should do it per object, especially if you have in your Preferences => Selection =>  Use object highlight setting
I did a few tests with a cube and unchecked/checked the Selection Child Highlighting checkbox for cube and its ctl - but it would still highlight the child.
It "works" only when you change it globally as  @hamsterHamster  mentioned. But I don't find the way to do it per object... only for direct parenting in the rig i do not want highlighted geo, all the other cases - I want children to be highlighted
Message 9 of 10
hamsterHamster
@Vstanish You are probably selecting the setting in the shape node, while shape itself is a child and (usually) has nothing underneath. Try finding same setting in the transform node - works like a charm here.
,,,_°(O__O)°_,,,
Message 10 of 10
Vstanish
Thank you a lot!!!  This is a miracle 🙂 it works!! 😄
New world is discovered! God bless you 🙂
