Sculpt tools mess up normals in Maya 2020
adamzeliaszEBGV8
Message 1 of 8
adamzeliaszEBGV8
When I use the sculpting brush, say the Grab tool, and start moving the mesh around the normals "break" and get distorted until I 'Soften Normals'.  Even if I do that it still happens when I use the tools again. Is there a setting I'm missing? I tried to 'Unlock Normals' but that doesn't fix the problem.
Thoughts? Thanks.
Replies (7)
Message 2 of 8
mspeer
Hi!
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
This seems to be happening with meshes that are not only based on quads
If you test this with a simple oily sphere, also faces can be deleted by this tool.
Message 3 of 8
Kyrla
I have the same problem. Some meshes work, some don't.
But in 2019 it works with all meshes!
There are only quads in the meshes I tested, so there must be another reason for that.
Message 4 of 8
Kyrla
me again;
I looked a bit closer at my mehs and it seems there are not only quads but it should work despite of that as it works in maya LT 2019!
Message 5 of 8
01. select the mesh with the messed up normals
02. go to Mesh display > set to Face options
03. in the "set to face Normal options" window select "unlock vertex face normals"
04. then click set to face and the mesh normals now will be corrected to face.
Message 6 of 8
Christoph_Schaedl
Thats a known bug. ::MAYA-102672
https://linktr.ee/cg_oglu
Message 7 of 8
chadvernon
Observer
Observer
This seems to be fixed in 2020.3
Message 8 of 8
rsharris632
Ya I seem to be having the same problem in Maya 2020.4 version as well.
