Rotate and Move Tool Guides Missing.
andrey_ivankin
andrey_ivankin
Community Visitor
Community Visitor
Whenever I use the Move, or Rotate tool the red, green, and blue things that you use to rotate or move the object are not showing, I have restated maya a few times but nothing changed.
baez_isaac
Hello Andrey,
 You might want to try and reset the tool using the "Tool settings". That's located in the top right corner and it looks like a small hammer. You can also try and reset your preference to default and see if that helps.
Hope this helps you out.
