Ridges visible in polys with Softened edges
Message 1 of 11
I'm currently working on a mesh that is perfectly smooth, however when I cut out a part of it to add some detail and then re-created the mesh ridges appeared. I have tried to Soften the edges again but the ridges stay. I'm sure it's Poly normal based but I have tried two different way of re-creating the mesh and both experience the same issue. I also tried to Average normals but I don't fully understand it and everything turned black. The mesh does have normals.
Attempt 1:
Ridges
https://gyazo.com/08b2584db0ebeee7b9988b2347571c40
Mesh
https://gyazo.com/8e97937f12728460044b73f19397c293
Attempt 2:
Ridges
https://gyazo.com/b4bb635352d9e22a67e13ae7fde6dd4b
Mesh
https://gyazo.com/b0c6d8a523387a95c51af4a3b74044e6
p.s. I know you dislike external links.
Replies (10)
Message 2 of 11
Lindsey_Robbins
If there are two vertexes in the same spot, but not welded, the edges around it will stay sharp. Perhaps select your whole model, merge verts with a tiny tolerance?
Message 3 of 11
I've attempted this and the issue persists 😞
Message 4 of 11
Lindsey_Robbins
Do you have any creases?
display>polygon>crease edges
Message 5 of 11
damaggio
Your topology seems clean but the top of gun needs to be fixed so the edges disappear , edges are not round on the top part and edge distribution needs to be better balanced .
The basic problem here is Edges close together will produce a sharp look so find the right topology solution for that section.
Message 6 of 11
I've never used that tool before but when I do nothing happens so I'm guessing not? But the creases are still there
Message 7 of 11
I tried a more linear approach of just adding an extra division down the entire barrel of the weapon but that didn't change anything. I'm not too sure what other methods I could use, I will have a jab and see what i can come up with though.
Message 8 of 11
damaggio
Just upload you file and someone will correct it for you, that's a common issue for beginners specially dealing with cylindrical shapes with holes in it.
its hard to explain step by step.
Message 9 of 11
Okay, So it is definitely Topology based. I have tried a new method and it has lessened the issue massively, I'm unsure if it's acceptable to have a small crease though?
New Topology - https://gyazo.com/4d9e4b41aeb0de0548afa7b28717c44f
New crease is attached
Message 10 of 11
damaggio
Well done! that was the correct solution.
hope you can finish and move on to texturing.
best regards .
Message 11 of 11
Cheers, I appreciate the help 🙂
